Giriş
This guide will help you if you experience difficulty hearing from ATT CL2940 handset. The common issue maybe with the ATT CL2940 handset cord. Using this guide, remove the cord and reattach it to determine if it was not plugged in securely. If this does not fix the problem, try replacing the old cord with a new one.
Bir başkası bu kılavuzu tamamladı.
