Ana içeriğe geç
ATT CL2940 Phone Jack Replacement
Neye ihtiyacın var
  1. ATT CL2940 Phone Jack Replacement, Back Panel: adım 1, 3 resimden 1. ATT CL2940 Phone Jack Replacement, Back Panel: adım 1, 3 resimden 2. ATT CL2940 Phone Jack Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. ATT CL2940 Phone Jack Replacement: adım 2, 3 resimden 1. ATT CL2940 Phone Jack Replacement: adım 2, 3 resimden 2. ATT CL2940 Phone Jack Replacement: adım 2, 3 resimden 3.
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
    FixBot'a Sor
    Yorum Ekle
  3. ATT CL2940 Phone Jack Replacement: adım 3, 1 resimden 1.
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
    FixBot'a Sor
    Yorum Ekle
  4. ATT CL2940 Phone Jack Replacement, Phone Jack: adım 4, 2 resimden 1. ATT CL2940 Phone Jack Replacement, Phone Jack: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the precision tweezers, bend the golden tips of the green and red wires upward.
    • The wires are pulled out from two of the six holes. Make sure you remember which holes you pulled the wires out from.
    • Bend the wires slowly and gently to avoid breaking them.
    FixBot'a Sor
    Yorum Ekle
  5. ATT CL2940 Phone Jack Replacement: adım 5, 3 resimden 1. ATT CL2940 Phone Jack Replacement: adım 5, 3 resimden 2. ATT CL2940 Phone Jack Replacement: adım 5, 3 resimden 3.
    • After bending the golden wire tips, pull the wires out from the back side of the phone jack.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Noor Assaf
312 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Spring 2016 IUPUI, Team 1-1, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S1G1
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 1,046
