Ana içeriğe geç
ATT CL4940 Internal Microphone Replacement
Neye ihtiyacın var
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: adım 1, 2 resimden 1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: adım 1, 2 resimden 2.
    • Unplug your device before beginning disassembly.
    • Remove the phone line and the power cord from the back of the device.
    • Remove the phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: adım 3, 3 resimden 1. ATT CL4940 Internal Microphone Replacement: adım 3, 3 resimden 2. ATT CL4940 Internal Microphone Replacement: adım 3, 3 resimden 3.
    • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: adım 4, 1 resimden 1.
    • Using wire cutters, sever both the red and the black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling it apart.
Sonuç
Charles Moore
201 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Harley Spring 2016 IUPUI, Team 2-2, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G2
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 593
