Ana içeriğe geç
ATT EL52300 Motherboard Replacement
Neye ihtiyacın var
  1. ATT EL52300 Motherboard Replacement, Battery: adım 1, 2 resimden 1. ATT EL52300 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
    FixBot'a Sor
    Yorum Ekle
  2. ATT EL52300 Motherboard Replacement: adım 2, 1 resimden 1.
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
    FixBot'a Sor
    Yorum Ekle
  3. ATT EL52300 Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. ATT EL52300 Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. ATT EL52300 Motherboard Replacement: adım 4, 2 resimden 1. ATT EL52300 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
    FixBot'a Sor
    Yorum Ekle
  5. ATT EL52300 Motherboard Replacement: adım 5, 2 resimden 1. ATT EL52300 Motherboard Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nam Mai
489 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Sullivan Spring 2016 USF Tampa, Team 1-1, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G1
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 955
