Ana içeriğe geç
ATT Trek HD 9020A Screen Replacement
Neye ihtiyacın var
  1. ATT Trek HD 9020A Screen Replacement, Back Cover: adım 1, 1 resimden 1.
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD 9020A Screen Replacement: adım 2, 1 resimden 1.
    • Pull the screen away from the back panel.
  3. ATT Trek HD 9020A Screen Replacement, Battery: adım 3, 2 resimden 1. ATT Trek HD 9020A Screen Replacement, Battery: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD 9020A Screen Replacement: adım 4, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
  5. ATT Trek HD 9020A Screen Replacement, Motherboard: adım 5, 2 resimden 1. ATT Trek HD 9020A Screen Replacement, Motherboard: adım 5, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
  6. ATT Trek HD 9020A Screen Replacement: adım 6, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
  7. ATT Trek HD 9020A Screen Replacement: adım 7, 1 resimden 1.
    • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
  8. ATT Trek HD 9020A Screen Replacement: adım 8, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
    • Use angled tweezers to pry up the black tab.
    • Use the angled tweezers to pull out the gold connector.
  9. ATT Trek HD 9020A Screen Replacement: adım 9, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 9, 2 resimden 2.
    • Use the angled tweezers to disconnect the gold connector.
  10. ATT Trek HD 9020A Screen Replacement: adım 10, 1 resimden 1.
    • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
  11. ATT Trek HD 9020A Screen Replacement: adım 11, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 11, 2 resimden 2.
    • Use the plastic opening tool to lift the motherboard out of place.
  12. ATT Trek HD 9020A Screen Replacement, Front Camera: adım 12, 2 resimden 1. ATT Trek HD 9020A Screen Replacement, Front Camera: adım 12, 2 resimden 2.
    $3.99
  13. ATT Trek HD 9020A Screen Replacement, Screen: adım 13, 3 resimden 1. ATT Trek HD 9020A Screen Replacement, Screen: adım 13, 3 resimden 2. ATT Trek HD 9020A Screen Replacement, Screen: adım 13, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
    • Gently lift the black corner pieces out of the device.
  14. ATT Trek HD 9020A Screen Replacement: adım 14, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 14, 2 resimden 2.
    $3.99
    • Use the angled tweezers to remove the black cables on each side of the device from their groove.
  15. ATT Trek HD 9020A Screen Replacement: adım 15, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 15, 2 resimden 2.
    • Use the plastic opening tool to disconnect the black cable connectors from each side of the device.
  16. ATT Trek HD 9020A Screen Replacement: adım 16, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 16, 2 resimden 2.
    • Remove the remaining ten 3 mm Phillips #00 screws.
  17. ATT Trek HD 9020A Screen Replacement: adım 17, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 17, 2 resimden 2.
    • Use the plastic opening tool to disconnect the remaining three gold connectors at the bottom of the device.
  18. ATT Trek HD 9020A Screen Replacement: adım 18, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 18, 2 resimden 2.
    • Use the plastic opening tool to pry up the grey plastic panel.
  19. ATT Trek HD 9020A Screen Replacement: adım 19, 2 resimden 1. ATT Trek HD 9020A Screen Replacement: adım 19, 2 resimden 2.
    • Use the plastic opening tool to pry the screen out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Cross
475 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 785
