Ana içeriğe geç
ATT Trek HD Battery Replacement
Neye ihtiyacın var
  1. ATT Trek HD Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
    FixBot'a Sor
    Yorum Ekle
  2. ATT Trek HD Battery Replacement: adım 2, 1 resimden 1.
    • Pull the screen away from the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. ATT Trek HD Battery Replacement, Battery: adım 3, 2 resimden 1. ATT Trek HD Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
    FixBot'a Sor
    Yorum Ekle
  4. ATT Trek HD Battery Replacement: adım 4, 2 resimden 1. ATT Trek HD Battery Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 1,504
