Giriş
This guide will show you how to replace the motherboard in the ATT Trek HD tablet. During this process, take your time and make sure to disconnect all parts before trying to remove the motherboard. Any damage done to the motherboard may cause the device to not work properly. Make sure to use the plastic opening tool when possible.
Neye ihtiyacın var
To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
