Ana içeriğe geç
ATT Trimline 210M Microphone Replacement
Neye ihtiyacın var
  1. ATT Trimline 210M Microphone Replacement, ATT Trimline 210M Back Cover Disassembly: adım 1, 1 resimden 1.
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Microphone Replacement: adım 2, 1 resimden 1.
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Microphone Replacement: adım 3, 1 resimden 1.
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Microphone Replacement: adım 4, 1 resimden 1.
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Microphone Replacement, ATT Trimline 210M Motherboard Disassembly: adım 5, 1 resimden 1.
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
  6. ATT Trimline 210M Microphone Replacement: adım 6, 1 resimden 1.
    • Carefully move the motherboard up to remove it.
  7. ATT Trimline 210M Microphone Replacement, Microphone: adım 7, 1 resimden 1.
    • Use metal spudger to remove the microphone
  8. ATT Trimline 210M Microphone Replacement: adım 8, 1 resimden 1.
    • Carefully detach the black and red wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Corey
343 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Lacy Spring 2016 USF Tampa, Team 4-2, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 292
