Ana içeriğe geç
ATT Trimline 210M Motherboard Disassembly
Neye ihtiyacın var
  1. ATT Trimline 210M Motherboard Disassembly, ATT Trimline 210M Back Cover Disassembly: adım 1, 1 resimden 1.
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Motherboard Disassembly: adım 2, 1 resimden 1.
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Motherboard Disassembly: adım 3, 1 resimden 1.
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Motherboard Disassembly: adım 4, 1 resimden 1.
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Motherboard Disassembly, ATT Trimline 210M Motherboard Disassembly: adım 5, 1 resimden 1.
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
  6. ATT Trimline 210M Motherboard Disassembly: adım 6, 1 resimden 1.
    • Carefully move the motherboard up to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Juan Carrillo
406 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Lacy Spring 2016 USF Tampa, Team 4-2, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 900
