Giriş
If you are looking to replace the motherboard of your ATT Trimline 210M, this guide will explain in detail how to do so yourself. Keep in mind through this process that the motherboard must be handled with care, as the wires attached to it help run the whole phone.
Neye ihtiyacın var
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
2 farklı kişi bu kılavuzu tamamladı.
