Ana içeriğe geç
AYL SoundFit Battery Replacement
Neye ihtiyacın var
  1. AYL SoundFit Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: adım 2, 1 resimden 1.
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: adım 3, 1 resimden 1.
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: adım 4, 2 resimden 1. AYL SoundFit Battery Replacement: adım 4, 2 resimden 2.
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: adım 5, 1 resimden 1.
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
Sonuç
Dustin Moore
108 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Spring 2016 IUPUI, Team 3-3, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S3G3
4 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
Which battery is this, and what is the mAH?
jlongsa - Yanıt
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - Yanıt
18650 battery
rich4349 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 2,726
