Ana içeriğe geç
Aarp RealPad MA7BX2 Speakers Replacement
Neye ihtiyacın var
  1. Aarp RealPad MA7BX2 Speakers Replacement, Speakers: adım 1, 1 resimden 1.
    • Loosen the back cover using the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. Aarp RealPad MA7BX2 Speakers Replacement: adım 2, 1 resimden 1.
    • Gently place the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the plastic opening tool.
  3. Aarp RealPad MA7BX2 Speakers Replacement: adım 3, 1 resimden 1.
    • Gently pull off the black tape.
  4. Aarp RealPad MA7BX2 Speakers Replacement: adım 4, 1 resimden 1.
    • Remove the wires with the tweezers by pulling them upward.
  5. Aarp RealPad MA7BX2 Speakers Replacement: adım 5, 2 resimden 1. Aarp RealPad MA7BX2 Speakers Replacement: adım 5, 2 resimden 2.
    • Pull the speakers upward with you hand.
Sonuç
To reassemble your device you will need to solder the wires back in position and then follow the other steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 165
