Neye ihtiyacın var
Loosen the back cover using the suction cup.
Pull up on all four corners of the back with the suction cup.
To reassemble your device you will need to solder the wires back in position and then follow the other steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
