Ana içeriğe geç
Accessing LCD Screen
Neye ihtiyacın var
  1. Accessing LCD Screen, Front and Back Cover: adım 1, 2 resimden 1. Accessing LCD Screen, Front and Back Cover: adım 1, 2 resimden 2.
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
    FixBot'a Sor
    Yorum Ekle
  2. Accessing LCD Screen: adım 2, 1 resimden 1.
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
    FixBot'a Sor
    Yorum Ekle
  3. Accessing LCD Screen: adım 3, 2 resimden 1. Accessing LCD Screen: adım 3, 2 resimden 2.
    • Carefully pull the back of casing away from the front.
    FixBot'a Sor
    Yorum Ekle
  4. Accessing LCD Screen: adım 4, 3 resimden 1. Accessing LCD Screen: adım 4, 3 resimden 2. Accessing LCD Screen: adım 4, 3 resimden 3.
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    FixBot'a Sor
    Yorum Ekle
  5. Accessing LCD Screen: adım 5, 2 resimden 1. Accessing LCD Screen: adım 5, 2 resimden 2.
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    FixBot'a Sor
    Yorum Ekle
  6. Accessing LCD Screen, LCD: adım 6, 2 resimden 1. Accessing LCD Screen, LCD: adım 6, 2 resimden 2.
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
    FixBot'a Sor
    Yorum Ekle
  7. Accessing LCD Screen: adım 7, 2 resimden 1. Accessing LCD Screen: adım 7, 2 resimden 2.
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
    FixBot'a Sor
    Yorum Ekle
  8. Accessing LCD Screen: adım 8, 1 resimden 1.
    • Pull the cover plate off for the two power cord jacks.
    FixBot'a Sor
    Yorum Ekle
  9. Accessing LCD Screen: adım 9, 3 resimden 1. Accessing LCD Screen: adım 9, 3 resimden 2. Accessing LCD Screen: adım 9, 3 resimden 3.
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
    FixBot'a Sor
    Yorum Ekle
  10. Accessing LCD Screen: adım 10, 1 resimden 1.
    • Remove the orange tape on top of the SD cardholder.
    FixBot'a Sor
    Yorum Ekle
  11. Accessing LCD Screen: adım 11, 3 resimden 1. Accessing LCD Screen: adım 11, 3 resimden 2. Accessing LCD Screen: adım 11, 3 resimden 3.
    • Open the battery cover and lift plastic piece off.
    FixBot'a Sor
    Yorum Ekle
  12. Accessing LCD Screen: adım 12, 1 resimden 1.
    • Remove tape on left side of camera.
    FixBot'a Sor
    Yorum Ekle
  13. Accessing LCD Screen: adım 13, 1 resimden 1.
    • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
    FixBot'a Sor
    Yorum Ekle
  14. Accessing LCD Screen: adım 14, 1 resimden 1.
    • Remove top left LCD bracket.
    • This is a small piece, be careful not to lose it.
    FixBot'a Sor
    Yorum Ekle
  15. Accessing LCD Screen: adım 15, 2 resimden 1. Accessing LCD Screen: adım 15, 2 resimden 2.
    • Push down bottom left LCD bracket to release the LCD from grip.
    FixBot'a Sor
    Yorum Ekle
  16. Accessing LCD Screen: adım 16, 1 resimden 1.
    • Gently lift up LCD screen.
    FixBot'a Sor
    Yorum Ekle
  17. Accessing LCD Screen: adım 17, 3 resimden 1. Accessing LCD Screen: adım 17, 3 resimden 2. Accessing LCD Screen: adım 17, 3 resimden 3.
    • Slowly pull LCD screen to the left to remove it from the other grips.
    • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bassem Tossoun
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-29, Regan Winter 2011 Cal Poly, Team 4-29, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G29
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 1,541
