Ana içeriğe geç
Accessing Nokia 3100b Vibrating Unit
Neye ihtiyacın var
  1. Accessing Nokia 3100b Vibrating Unit, Battery: adım 1, 1 resimden 1.
    • Make sure your phone is turned off.
    FixBot'a Sor
    Yorum Ekle
  2. Accessing Nokia 3100b Vibrating Unit: adım 2, 1 resimden 1.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Accessing Nokia 3100b Vibrating Unit, SIM Card: adım 3, 1 resimden 1.
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    FixBot'a Sor
    Yorum Ekle
  4. Accessing Nokia 3100b Vibrating Unit: adım 4, 1 resimden 1.
    • Retrieve your SIM card.
    FixBot'a Sor
    Yorum Ekle
  5. Accessing Nokia 3100b Vibrating Unit, Vibrating Unit: adım 5, 1 resimden 1.
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
    FixBot'a Sor
    Yorum Ekle
  6. Accessing Nokia 3100b Vibrating Unit: adım 6, 1 resimden 1.
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
    FixBot'a Sor
    Yorum Ekle
  7. Accessing Nokia 3100b Vibrating Unit: adım 7, 1 resimden 1.
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
    FixBot'a Sor
    Yorum Ekle
  8. Accessing Nokia 3100b Vibrating Unit: adım 8, 1 resimden 1.
    • The vibrating unit can now be accessed. Note its location in the phone.
    FixBot'a Sor
    Yorum Ekle
  9. Accessing Nokia 3100b Vibrating Unit: adım 9, 1 resimden 1.
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
    FixBot'a Sor
    Yorum Ekle
  10. Accessing Nokia 3100b Vibrating Unit: adım 10, 1 resimden 1.
    • The vibrating unit is now removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sterling Fuentes
139 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G64
3 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 35
Her zaman: 1,987
