Ana içeriğe geç
Accessing Samsung ML2510 Circuit Board
Neye ihtiyacın var
  1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 2. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 3.
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Accessing Samsung ML2510 Circuit Board: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Accessing Samsung ML2510 Circuit Board: adım 3, 3 resimden 1. Accessing Samsung ML2510 Circuit Board: adım 3, 3 resimden 2. Accessing Samsung ML2510 Circuit Board: adım 3, 3 resimden 3.
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: adım 4, 3 resimden 1. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: adım 4, 3 resimden 2. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: adım 4, 3 resimden 3.
    • Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
  5. Accessing Samsung ML2510 Circuit Board: adım 5, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Accessing Samsung ML2510 Circuit Board: adım 6, 3 resimden 1. Accessing Samsung ML2510 Circuit Board: adım 6, 3 resimden 2. Accessing Samsung ML2510 Circuit Board: adım 6, 3 resimden 3.
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Accessing Samsung ML2510 Circuit Board: adım 7, 3 resimden 1. Accessing Samsung ML2510 Circuit Board: adım 7, 3 resimden 2. Accessing Samsung ML2510 Circuit Board: adım 7, 3 resimden 3.
    • Lift the right panel up from the raised stops.
    • Rotate the panel gently as indicated in the picture to remove the panel entirely.
  8. Accessing Samsung ML2510 Circuit Board: adım 8, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the four 1" screws attaching the gray plate to the printer.
    • Remove the plastic cover by sliding it carefully under the silver hinges on the right.
  9. Accessing Samsung ML2510 Circuit Board: adım 9, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the 1" screw attaching the circuit board to the printer.
  10. Accessing Samsung ML2510 Circuit Board: adım 10, 2 resimden 1. Accessing Samsung ML2510 Circuit Board: adım 10, 2 resimden 2.
    • Turn over the circuit board to access main wiring.
    • Unplug the wiring from the circuit board gently.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
bbaustin
268 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G18
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 2,829
