Giriş
This guide will require you to disassemble the rear and side panels of the printer in order to access the circuit board.
Neye ihtiyacın var
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
3 farklı kişi bu kılavuzu tamamladı.
