Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Accessing Samsung ML2510 Circuit Board
Neye ihtiyacın var
  1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 2. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 3.
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Accessing Samsung ML2510 Circuit Board: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Accessing Samsung ML2510 Circuit Board: adım 3, 3 resimden 1. Accessing Samsung ML2510 Circuit Board: adım 3, 3 resimden 2. Accessing Samsung ML2510 Circuit Board: adım 3, 3 resimden 3.
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: adım 4, 3 resimden 1. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: adım 4, 3 resimden 2. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: adım 4, 3 resimden 3.
    • Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
  5. Accessing Samsung ML2510 Circuit Board: adım 5, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Accessing Samsung ML2510 Circuit Board: adım 6, 3 resimden 1. Accessing Samsung ML2510 Circuit Board: adım 6, 3 resimden 2. Accessing Samsung ML2510 Circuit Board: adım 6, 3 resimden 3.
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Accessing Samsung ML2510 Circuit Board: adım 7, 3 resimden 1. Accessing Samsung ML2510 Circuit Board: adım 7, 3 resimden 2. Accessing Samsung ML2510 Circuit Board: adım 7, 3 resimden 3.
    • Lift the right panel up from the raised stops.
    • Rotate the panel gently as indicated in the picture to remove the panel entirely.
  8. Accessing Samsung ML2510 Circuit Board: adım 8, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the four 1" screws attaching the gray plate to the printer.
    • Remove the plastic cover by sliding it carefully under the silver hinges on the right.
  9. Accessing Samsung ML2510 Circuit Board: adım 9, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the 1" screw attaching the circuit board to the printer.
  10. Accessing Samsung ML2510 Circuit Board: adım 10, 2 resimden 1. Accessing Samsung ML2510 Circuit Board: adım 10, 2 resimden 2.
    • Turn over the circuit board to access main wiring.
    • Unplug the wiring from the circuit board gently.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
bbaustin
268 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G18
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 2,829
