Ana içeriğe geç
Acer AL1714 LCD Replacement
Neye ihtiyacın var
  1. Acer AL1714 LCD Replacement, LCD: adım 1, 2 resimden 1. Acer AL1714 LCD Replacement, LCD: adım 1, 2 resimden 2.
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
    FixBot'a Sor
    Yorum Ekle
  2. Acer AL1714 LCD Replacement: adım 2, 3 resimden 1. Acer AL1714 LCD Replacement: adım 2, 3 resimden 2. Acer AL1714 LCD Replacement: adım 2, 3 resimden 3.
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
    • (This will require some force, you will hear a loud popping/snapping noises)
    FixBot'a Sor
    Yorum Ekle
  3. Acer AL1714 LCD Replacement: adım 3, 3 resimden 1. Acer AL1714 LCD Replacement: adım 3, 3 resimden 2. Acer AL1714 LCD Replacement: adım 3, 3 resimden 3.
    • Remove the Power Button Circuit Board Flat Flex Cable from the Power Supply board under the metal cover.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
    FixBot'a Sor
    Yorum Ekle
  4. Acer AL1714 LCD Replacement: adım 4, 3 resimden 1. Acer AL1714 LCD Replacement: adım 4, 3 resimden 2. Acer AL1714 LCD Replacement: adım 4, 3 resimden 3.
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
    FixBot'a Sor
    Yorum Ekle
  5. Acer AL1714 LCD Replacement: adım 5, 2 resimden 1. Acer AL1714 LCD Replacement: adım 5, 2 resimden 2.
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flat Power Cable cover in place.
    • Lift up and remove the Flat Power Cable cover.
    • (Careful: it may be sharp)
    FixBot'a Sor
    Yorum Ekle
  6. Acer AL1714 LCD Replacement: adım 6, 1 resimden 1.
    • Unscrew the 5 screws holding the metal cage on.
    FixBot'a Sor
    Yorum Ekle
  7. Acer AL1714 LCD Replacement: adım 7, 2 resimden 1. Acer AL1714 LCD Replacement: adım 7, 2 resimden 2.
    • Lift up on the back of metal cage, slightly.
    • Pull the cage toward self.
    • (Must be careful to free cover of the VGA port and power supply input)
    FixBot'a Sor
    Yorum Ekle
  8. Acer AL1714 LCD Replacement: adım 8, 3 resimden 1. Acer AL1714 LCD Replacement: adım 8, 3 resimden 2. Acer AL1714 LCD Replacement: adım 8, 3 resimden 3.
    • Lift up on the Flat Flex Cable holder tabs to release the cords.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
    FixBot'a Sor
    Yorum Ekle
  9. Acer AL1714 LCD Replacement: adım 9, 3 resimden 1. Acer AL1714 LCD Replacement: adım 9, 3 resimden 2. Acer AL1714 LCD Replacement: adım 9, 3 resimden 3.
    • Unplug the 4 backlight wires from their ports on the Power Supply board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling and pulling the wires out of place)
    FixBot'a Sor
    Yorum Ekle
  10. Acer AL1714 LCD Replacement: adım 10, 1 resimden 1.
    • Unscrew the 5 screws holding the Power Supply and Video Display boards.
    FixBot'a Sor
    Yorum Ekle
  11. Acer AL1714 LCD Replacement: adım 11, 2 resimden 1. Acer AL1714 LCD Replacement: adım 11, 2 resimden 2.
    • Lift and remove the joined Power Supply and Video Display boards.
    FixBot'a Sor
    Yorum Ekle
  12. Acer AL1714 LCD Replacement: adım 12, 3 resimden 1. Acer AL1714 LCD Replacement: adım 12, 3 resimden 2. Acer AL1714 LCD Replacement: adım 12, 3 resimden 3.
    • Carefully detach the Power Supply and Video Display boards at the connector joint.
    • (This step is not necessary to replace the LCD Module. This step is only a safety precaution so as not to bend or break the Power Supply connector joint)
    FixBot'a Sor
    Yorum Ekle
  13. Acer AL1714 LCD Replacement: adım 13, 1 resimden 1.
    • Remove the Flat Flex Cable from the Power Button Circuit board.
    FixBot'a Sor
    Yorum Ekle
  14. Acer AL1714 LCD Replacement: adım 14, 3 resimden 1. Acer AL1714 LCD Replacement: adım 14, 3 resimden 2. Acer AL1714 LCD Replacement: adım 14, 3 resimden 3.
    • Grasp, lift, and remove the LCD Module from the front panel.
    FixBot'a Sor
    Yorum Ekle
  15. Acer AL1714 LCD Replacement: adım 15, 1 resimden 1.
    • The final product with the LCD Module removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Christopher Kelly
590 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Brown Fall 2014 USF Tampa, Team 1-3, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 21
Son 30 gün: 91
Her zaman: 3,810
