Ana içeriğe geç
Acer AL1714 Power Button Circuit Board Flat Flex Cables Replacement
Neye ihtiyacın var
  1. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: adım 1, 2 resimden 1. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: adım 1, 2 resimden 2.
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: adım 2, 3 resimden 1. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: adım 2, 3 resimden 2. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: adım 2, 3 resimden 3.
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: adım 3, 3 resimden 1. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: adım 3, 3 resimden 2. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: adım 3, 3 resimden 3.
    • Remove the Power Button Circuit board Flat Flex Cable from the Power Supply board under the metal cage.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: adım 4, 1 resimden 1.
    • Remove the Flat Flex Cables from the Power Button Circuit Board.
Sonuç
Christopher Kelly
590 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Brown Fall 2014 USF Tampa, Team 1-3, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 706
