Ana içeriğe geç
Acer AL1714 Power Button Circuit Board
Neye ihtiyacın var
  1. Acer AL1714 Power Button Circuit Board, Power Button Circuit Board: adım 1, 2 resimden 1. Acer AL1714 Power Button Circuit Board, Power Button Circuit Board: adım 1, 2 resimden 2.
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Button Circuit Board: adım 2, 3 resimden 1. Acer AL1714 Power Button Circuit Board: adım 2, 3 resimden 2. Acer AL1714 Power Button Circuit Board: adım 2, 3 resimden 3.
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Button Circuit Board: adım 3, 3 resimden 1. Acer AL1714 Power Button Circuit Board: adım 3, 3 resimden 2. Acer AL1714 Power Button Circuit Board: adım 3, 3 resimden 3.
    • Remove the Flat Flex Cable from the Power Supply Board under the metal cover.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Button Circuit Board: adım 4, 3 resimden 1. Acer AL1714 Power Button Circuit Board: adım 4, 3 resimden 2. Acer AL1714 Power Button Circuit Board: adım 4, 3 resimden 3.
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
  5. Acer AL1714 Power Button Circuit Board: adım 5, 2 resimden 1. Acer AL1714 Power Button Circuit Board: adım 5, 2 resimden 2.
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flex Power Cable cover.
    • Lift up and remove the Flex Power Cable cover.
    • (Careful: This may be sharp)
  6. Acer AL1714 Power Button Circuit Board: adım 6, 1 resimden 1.
    • Unscrew the 5 screws holding the metal cage on.
  7. Acer AL1714 Power Button Circuit Board: adım 7, 2 resimden 1. Acer AL1714 Power Button Circuit Board: adım 7, 2 resimden 2.
    • Lift up on the back of the metal cage slightly.
    • Pull the cage toward self.
    • (Must be careful to free the cover of the VGA port and power supply input)
  8. Acer AL1714 Power Button Circuit Board: adım 8, 3 resimden 1. Acer AL1714 Power Button Circuit Board: adım 8, 3 resimden 2. Acer AL1714 Power Button Circuit Board: adım 8, 3 resimden 3.
    • Lift up on the Flat Flex Cable holder tabs to release cords.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
  9. Acer AL1714 Power Button Circuit Board: adım 9, 3 resimden 1. Acer AL1714 Power Button Circuit Board: adım 9, 3 resimden 2. Acer AL1714 Power Button Circuit Board: adım 9, 3 resimden 3.
    • Unplug the 4 backlight wires from their ports on the Power Supply Board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling wires out of place)
  10. Acer AL1714 Power Button Circuit Board: adım 10, 1 resimden 1.
    • Unscrew the 5 screws holding the Power Supply Board and Video Display boards on.
  11. Acer AL1714 Power Button Circuit Board: adım 11, 2 resimden 1. Acer AL1714 Power Button Circuit Board: adım 11, 2 resimden 2.
    • Lift up and remove the joined Power Supply Board and Video Display boards.
  12. Acer AL1714 Power Button Circuit Board: adım 12, 3 resimden 1. Acer AL1714 Power Button Circuit Board: adım 12, 3 resimden 2. Acer AL1714 Power Button Circuit Board: adım 12, 3 resimden 3.
    • Carefully detach the Power Supply and Video Display boards at their connector joint.
    • (This step is not necessary for the removal and replacement of the Power Button Circuit board)
    • (This is only a precaution so as not to bend or break the connector joint between the two boards)
  13. Acer AL1714 Power Button Circuit Board: adım 13, 1 resimden 1.
    • Remove the Flat Flex Cable from the Power Button Circuit Board.
  14. Acer AL1714 Power Button Circuit Board: adım 14, 3 resimden 1. Acer AL1714 Power Button Circuit Board: adım 14, 3 resimden 2. Acer AL1714 Power Button Circuit Board: adım 14, 3 resimden 3.
    • Grasp, lift, and remove the LCD Module from the front panel.
  15. Acer AL1714 Power Button Circuit Board: adım 15, 2 resimden 1. Acer AL1714 Power Button Circuit Board: adım 15, 2 resimden 2.
    • Unscrew the 2 screws holding the Power Button Circuit Board.
  16. Acer AL1714 Power Button Circuit Board: adım 16, 1 resimden 1.
    • Lift and remove the Power Button Circuit Board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Hussam Alzamzami
216 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Brown Fall 2014 USF Tampa, Team 1-3, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,758
