Ana içeriğe geç
Acer AL1714 Video Display Board
Neye ihtiyacın var
    1. Acer AL1714 Video Display Board, Video Display Board: adım 1, 2 resimden 1. Acer AL1714 Video Display Board, Video Display Board: adım 1, 2 resimden 2.
      • Turn the monitor face-down.
      • Unscrew the 5 screws holding back cover on.
      • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
      FixBot'a Sor
      Yorum Ekle
    2. Acer AL1714 Video Display Board: adım 2, 3 resimden 1. Acer AL1714 Video Display Board: adım 2, 3 resimden 2. Acer AL1714 Video Display Board: adım 2, 3 resimden 3.
      • Take the edge tool or a metal ruler and insert it into the bezel.
      • Apply pressure and push down.
      • Do the same to the right side.
      • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
      FixBot'a Sor
      Yorum Ekle
    3. Acer AL1714 Video Display Board: adım 3, 3 resimden 1. Acer AL1714 Video Display Board: adım 3, 3 resimden 2. Acer AL1714 Video Display Board: adım 3, 3 resimden 3.
      • Remove the Flat Flex Cable from the Power Supply board located under the metal cage.
      • Pull the cord back and out of the way.
      • (It may be stuck down with adhesive)
      FixBot'a Sor
      Yorum Ekle
    4. Acer AL1714 Video Display Board: adım 4, 3 resimden 1. Acer AL1714 Video Display Board: adım 4, 3 resimden 2. Acer AL1714 Video Display Board: adım 4, 3 resimden 3.
      • Unscrew the cord anchors for the VGA port.
      • (Use needle nose pliers if they're too tight for removal by hand)
      FixBot'a Sor
      Yorum Ekle
    5. Acer AL1714 Video Display Board: adım 5, 2 resimden 1. Acer AL1714 Video Display Board: adım 5, 2 resimden 2.
      • Turn the monitor around.
      • Unscrew the 1 screw holding the Flat power Cable cover on.
      • Lift up and remove the Flat Power Cable cover.
      • (Careful: this may be sharp)
      FixBot'a Sor
      Yorum Ekle
    6. Acer AL1714 Video Display Board: adım 6, 1 resimden 1.
      • Unscrew the 5 screws holding the metal cage on.
      FixBot'a Sor
      Yorum Ekle
    7. Acer AL1714 Video Display Board: adım 7, 2 resimden 1. Acer AL1714 Video Display Board: adım 7, 2 resimden 2.
      • Lift the back of the metal cage slightly.
      • Pull the cage toward self.
      • (Must be careful to free the cover of the VGA port and the power supply input)
      FixBot'a Sor
      Yorum Ekle
    8. Acer AL1714 Video Display Board: adım 8, 3 resimden 1. Acer AL1714 Video Display Board: adım 8, 3 resimden 2. Acer AL1714 Video Display Board: adım 8, 3 resimden 3.
      • Lift the Flat Flex Cable holder tabs to release the cables.
      • Lift up on the Flat Flex Cables and bend them out of the working area.
      FixBot'a Sor
      Yorum Ekle
    9. Acer AL1714 Video Display Board: adım 9, 3 resimden 1. Acer AL1714 Video Display Board: adım 9, 3 resimden 2. Acer AL1714 Video Display Board: adım 9, 3 resimden 3.
      • Unplug the 4 backlight wires from their ports on the Power Supply Board.
      • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling the wires out of place)
      FixBot'a Sor
      Yorum Ekle
    10. Acer AL1714 Video Display Board: adım 10, 1 resimden 1.
      • Unscrew the 5 screws holding the Power Supply and Video Display boards.
      FixBot'a Sor
      Yorum Ekle
    11. Acer AL1714 Video Display Board: adım 11, 2 resimden 1. Acer AL1714 Video Display Board: adım 11, 2 resimden 2.
      • Lift and remove the joined boards.
      FixBot'a Sor
      Yorum Ekle
    12. Acer AL1714 Video Display Board: adım 12, 3 resimden 1. Acer AL1714 Video Display Board: adım 12, 3 resimden 2. Acer AL1714 Video Display Board: adım 12, 3 resimden 3.
      • Carefully detach the two boards at their connector joint.
      • Replace outlined part.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christopher Kelly
590 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Brown Fall 2014 USF Tampa, Team 1-3, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 1,286
