Ana içeriğe geç
Acer AL1916 Display Replacement
Neye ihtiyacın var
  1. Acer AL1916 Display Replacement, Stand: adım 1, 1 resimden 1.
    • Lay the monitor on a flat surface so that the back is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Acer AL1916 Display Replacement: adım 2, 2 resimden 1. Acer AL1916 Display Replacement: adım 2, 2 resimden 2.
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
    FixBot'a Sor
    Yorum Ekle
  3. Acer AL1916 Display Replacement: adım 3, 2 resimden 1. Acer AL1916 Display Replacement: adım 3, 2 resimden 2.
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
    FixBot'a Sor
    Yorum Ekle
  4. Acer AL1916 Display Replacement, Outer Case: adım 4, 2 resimden 1. Acer AL1916 Display Replacement, Outer Case: adım 4, 2 resimden 2.
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
    FixBot'a Sor
    Yorum Ekle
  5. Acer AL1916 Display Replacement: adım 5, 3 resimden 1. Acer AL1916 Display Replacement: adım 5, 3 resimden 2. Acer AL1916 Display Replacement: adım 5, 3 resimden 3.
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
    FixBot'a Sor
    Yorum Ekle
  6. Acer AL1916 Display Replacement: adım 6, 2 resimden 1. Acer AL1916 Display Replacement: adım 6, 2 resimden 2.
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
    FixBot'a Sor
    Yorum Ekle
  7. Acer AL1916 Display Replacement, EMI Shield: adım 7, 2 resimden 1. Acer AL1916 Display Replacement, EMI Shield: adım 7, 2 resimden 2.
    • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
    FixBot'a Sor
    Yorum Ekle
  8. Acer AL1916 Display Replacement: adım 8, 2 resimden 1. Acer AL1916 Display Replacement: adım 8, 2 resimden 2.
    • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
    FixBot'a Sor
    Yorum Ekle
  9. Acer AL1916 Display Replacement: adım 9, 3 resimden 1. Acer AL1916 Display Replacement: adım 9, 3 resimden 2. Acer AL1916 Display Replacement: adım 9, 3 resimden 3.
    • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
    • Lift up to remove the metal casing.
    • Beware, metal casing is sharp!
    FixBot'a Sor
    Yorum Ekle
  10. Acer AL1916 Display Replacement, Display: adım 10, 2 resimden 1. Acer AL1916 Display Replacement, Display: adım 10, 2 resimden 2.
    • Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
    FixBot'a Sor
    Yorum Ekle
  11. Acer AL1916 Display Replacement: adım 11, 3 resimden 1. Acer AL1916 Display Replacement: adım 11, 3 resimden 2. Acer AL1916 Display Replacement: adım 11, 3 resimden 3.
    • Remove the two pieces of yellow tape on the left side of the power supply.
    FixBot'a Sor
    Yorum Ekle
  12. Acer AL1916 Display Replacement: adım 12, 2 resimden 1. Acer AL1916 Display Replacement: adım 12, 2 resimden 2.
    • Remove the four little white clips located underneath the pieces of tape by lifting up on their left side.
    FixBot'a Sor
    Yorum Ekle
  13. Acer AL1916 Display Replacement: adım 13, 3 resimden 1. Acer AL1916 Display Replacement: adım 13, 3 resimden 2. Acer AL1916 Display Replacement: adım 13, 3 resimden 3.
    • With the needle-nose pliers, remove the four display connectors by pulling directly left.
    FixBot'a Sor
    Yorum Ekle
  14. Acer AL1916 Display Replacement: adım 14, 3 resimden 1. Acer AL1916 Display Replacement: adım 14, 3 resimden 2. Acer AL1916 Display Replacement: adım 14, 3 resimden 3.
    • Remove the display cable located at the top of the circuit board by pulling it out towards the top of the monitor.
    FixBot'a Sor
    Yorum Ekle
  15. Acer AL1916 Display Replacement: adım 15, 3 resimden 1. Acer AL1916 Display Replacement: adım 15, 3 resimden 2. Acer AL1916 Display Replacement: adım 15, 3 resimden 3.
    • Turn the monitor on its side so that the power supply and circuit board are facing to the right
    • Remove the two 6.6 mm Phillips #2 screws located on both sides of the metal casing (four screws total).
    FixBot'a Sor
    Yorum Ekle
  16. Acer AL1916 Display Replacement: adım 16, 2 resimden 1. Acer AL1916 Display Replacement: adım 16, 2 resimden 2.
    • Set the monitor back down so that the power supply and circuit board are facing you.
    • Feed all four of the connector wires down through the metal casing.
    FixBot'a Sor
    Yorum Ekle
  17. Acer AL1916 Display Replacement: adım 17, 3 resimden 1. Acer AL1916 Display Replacement: adım 17, 3 resimden 2. Acer AL1916 Display Replacement: adım 17, 3 resimden 3.
    • Grab the sides of the metal casing and lift up.
    • Turn the display over to see the front; you are ready replace the broken display with a new one!
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Keith
375 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G26
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 9,964
