Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Replacing your display will give you a fresh new screen when your old one is not functioning properly.
Neye ihtiyacın var
Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
Tilt the plastic opening tool up to separate the back cover from the display bezel.
Continue around the perimeter of the monitor until the display bezel comes off.
Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
5 farklı kişi bu kılavuzu tamamladı.
