Ana içeriğe geç
Acer AL1916 Motherboard Replacement
Neye ihtiyacın var
  1. Acer AL1916 Motherboard Replacement, Stand: adım 1, 1 resimden 1.
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Motherboard Replacement: adım 2, 2 resimden 1. Acer AL1916 Motherboard Replacement: adım 2, 2 resimden 2.
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Motherboard Replacement: adım 3, 2 resimden 1. Acer AL1916 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
    I can't get a grip to squeeze and lift the hinge cover. My fingers just slide right off.
    az_irocdriver - Yanıt
  4. Acer AL1916 Motherboard Replacement, Outer Case: adım 4, 2 resimden 1. Acer AL1916 Motherboard Replacement, Outer Case: adım 4, 2 resimden 2.
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 Motherboard Replacement: adım 5, 3 resimden 1. Acer AL1916 Motherboard Replacement: adım 5, 3 resimden 2. Acer AL1916 Motherboard Replacement: adım 5, 3 resimden 3.
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 Motherboard Replacement: adım 6, 2 resimden 1. Acer AL1916 Motherboard Replacement: adım 6, 2 resimden 2.
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
  7. Acer AL1916 Motherboard Replacement, EMI Shield: adım 7, 2 resimden 1. Acer AL1916 Motherboard Replacement, EMI Shield: adım 7, 2 resimden 2.
    • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
  8. Acer AL1916 Motherboard Replacement: adım 8, 2 resimden 1. Acer AL1916 Motherboard Replacement: adım 8, 2 resimden 2.
    • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
  9. Acer AL1916 Motherboard Replacement: adım 9, 3 resimden 1. Acer AL1916 Motherboard Replacement: adım 9, 3 resimden 2. Acer AL1916 Motherboard Replacement: adım 9, 3 resimden 3.
    • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
    • Lift up to remove the metal casing.
    • Beware, metal casing is sharp!
  10. Acer AL1916 Motherboard Replacement, Motherboard: adım 10, 2 resimden 1. Acer AL1916 Motherboard Replacement, Motherboard: adım 10, 2 resimden 2.
    • Remove the beige control cable to the left of the VGA input by pulling it up.
  11. Acer AL1916 Motherboard Replacement: adım 11, 2 resimden 1. Acer AL1916 Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the rainbow-colored power cable by pulling it straight up.
  12. Acer AL1916 Motherboard Replacement: adım 12, 2 resimden 1. Acer AL1916 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the display cable located at the top of the motherboard by pulling it out towards the top of the monitor.
  13. Acer AL1916 Motherboard Replacement: adım 13, 3 resimden 1. Acer AL1916 Motherboard Replacement: adım 13, 3 resimden 2. Acer AL1916 Motherboard Replacement: adım 13, 3 resimden 3.
    • Remove the three 7.7 mm Phillips #2 screws from the motherboard, and take out the motherboard by lifting it up.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Taylor Atterbury
717 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G26
4 Üyeler
14 adet Kılavuz yazıldı
3 Yorum
How does one know weather it's the Motherboard or the PSU? What should the PSU be outputting to check it first? Or any other ways to check it
Tyler Wight - Yanıt
there are a few things that can help diagnose whether it is the power supply or the circuit board but sometimes it can be both. One thing you can do is just knowing the conditions of the home, did you have some power outage, or blinking of lights during storms and things like that. If you don't have a battery backup sometimes surge protectors are not going to save a system from failure just from power blinking on and off. This can cause backfire like issues that can glitch out the control board or power supply or domino the both. If you see power and the light turns on but when you hit the buttons nothing happens that either means the circuit board is failed because it is unable to process commands, or the power supply is only providing enough power to turn on the circuit board but nothing else. If you can not get a light at all and have tried plugging it in and out over and over and nothing no lights or anything than it is a good bet the power board has failed. If you don'twant to pay repairs take best guess
jamhi - Yanıt
Very often, espacially if the PSU is som years old, the electrolyt capacitors will dry out.
You can see it when the surface has blown up and is rounded. Normally this capacitors are flat. If you see, that one or more of this capacitors is bended, than replace all with the same values (capacity and voltage).
Eugen Schöller - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 7,944
