Ana içeriğe geç
Acer AL1916 Stand Replacement
Neye ihtiyacın var
  1. Acer AL1916 Stand Replacement, Stand: adım 1, 1 resimden 1.
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Stand Replacement: adım 2, 2 resimden 1. Acer AL1916 Stand Replacement: adım 2, 2 resimden 2.
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Stand Replacement: adım 3, 2 resimden 1. Acer AL1916 Stand Replacement: adım 3, 2 resimden 2.
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Keith
351 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G26
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Worked great…never would have guessed how to do it. Thanks.
GREG HILL - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 20,241
