Ana içeriğe geç
Acer Aspire 3 A315-21-92FX Speakers Replacement
Neye ihtiyacın var
  1. Acer Aspire 3 A315-21-92FX Speakers Replacement, RAM: adım 1, 1 resimden 1.
    • Flip the Acer Aspire 3 A315-21-92FX over so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 2, 2 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 2, 2 resimden 2.
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 3, 1 resimden 1.
    • Use the iFixit opening tool to remove the small cover.
  4. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 4, 3 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 4, 3 resimden 2. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 4, 3 resimden 3.
    • Press the tabs on each side of the RAM outwards, and the memory module will pop up at an angle.
  5. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 5, 2 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 5, 2 resimden 2.
    • Pull the RAM slowly out of the Acer Aspire 3 A315-21-92FX.
  6. Acer Aspire 3 A315-21-92FX Speakers Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  7. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 7, 2 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 7, 2 resimden 2.
  8. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 8, 1 resimden 1.
    • Use the iFixit opening tool to remove the cover of the hard disk.
  9. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 9, 2 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 9, 2 resimden 2.
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
  10. Acer Aspire 3 A315-21-92FX Speakers Replacement, Battery: adım 10, 1 resimden 1.
    • Remove fourteen 2.5mm Phillips #0 screws from the back of the laptop.
    • There may be two additional screws under the hard drive cover that must be removed before attempting to remove the back cover.
  11. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 11, 3 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 11, 3 resimden 2. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 11, 3 resimden 3.
    • Use the iFixit opening tool to remove the back cover.
  12. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 12, 2 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 12, 2 resimden 2.
    • Pull out the plug connecting the battery to the motherboard.
  13. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 13, 2 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 13, 2 resimden 2.
    • Pull the battery out of the groove.
  14. Acer Aspire 3 A315-21-92FX Speakers Replacement, Speakers: adım 14, 1 resimden 1.
    • Remove the speaker located in the right hand of the device first using the iFixit Opening Tool.
    • Place the edge of the iFixit Opening Tool under the speaker and pull it upward.
  15. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 15, 1 resimden 1.
    • Remove the speaker from the left side of the computer using the iFixit Opening Tool.
  16. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 16, 2 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 16, 2 resimden 2.
    • The cable that is connecting the speakers to the motherboard is placed under these plastic cables that are glued to the computer.
    • Remove these glued cables using the iFixit Opening Tool.
  17. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 17, 3 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 17, 3 resimden 2. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 17, 3 resimden 3.
    • Detach the speaker connector from the motherboard with your fingers or the iFixit Opening Tool.
  18. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 18, 2 resimden 1. Acer Aspire 3 A315-21-92FX Speakers Replacement: adım 18, 2 resimden 2.
    • Remove the speakers with your hands.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
gghhh
335 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 28
Her zaman: 1,651
