Ana içeriğe geç
Acer Aspire 3 A315-24P-R7VH Speaker Replacement
Neye ihtiyacın var
  1. Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Lower Case: adım 1, 1 resimden 1.
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: adım 2, 2 resimden 1. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: adım 2, 2 resimden 2.
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: adım 3, 1 resimden 1.
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Speaker: adım 5, 2 resimden 1. Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Find the speakers at the bottom left and right corners of the laptop.
  6. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: adım 6, 1 resimden 1.
    • Unplug each speaker carefully.
    • There are no screws holding the speakers in place, so once unplugged, lift them out.
  7. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: adım 7, 2 resimden 1. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: adım 7, 2 resimden 2.
    • Plug in the new speaker and place it in the corner that correlates to its shape. The speaker that is to go to the left corner of the laptop will be labeled with an L, likewise the speaker for the right will be labeled with an R.
Sonuç
AlexHarpring
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Pee Fall 2023 Gateway, Team 1-1, Pee Fall 2023 üyesi
GCC-PEE-F23S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 47
