Ana içeriğe geç
Acer Aspire 3 A315-58-350L Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire 3 A315-58-350L Battery Replacement, Lower Case: adım 1, 2 resimden 1. Acer Aspire 3 A315-58-350L Battery Replacement, Lower Case: adım 1, 2 resimden 2.
    • Remove the eleven 7 mm Phillips screws that secure the lower case.
  2. Acer Aspire 3 A315-58-350L Battery Replacement: adım 2, 3 resimden 1. Acer Aspire 3 A315-58-350L Battery Replacement: adım 2, 3 resimden 2. Acer Aspire 3 A315-58-350L Battery Replacement: adım 2, 3 resimden 3.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry along the perimeter until the lower case releases.
    • Lift off the lower case.
  3. Acer Aspire 3 A315-58-350L Battery Replacement, Battery: adım 3, 2 resimden 1. Acer Aspire 3 A315-58-350L Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the two 4 mm Phillips screws that secure the battery.
  4. Acer Aspire 3 A315-58-350L Battery Replacement: adım 4, 3 resimden 1. Acer Aspire 3 A315-58-350L Battery Replacement: adım 4, 3 resimden 2. Acer Aspire 3 A315-58-350L Battery Replacement: adım 4, 3 resimden 3.
    • Use tweezers to peel off the black strips of tape on the top of the battery
  5. Acer Aspire 3 A315-58-350L Battery Replacement: adım 5, 2 resimden 1. Acer Aspire 3 A315-58-350L Battery Replacement: adım 5, 2 resimden 2.
    • Use tweezers to grip the white battery connector and pull it directly out of its motherboard port.
    • Do not pull on the wires.
  6. Acer Aspire 3 A315-58-350L Battery Replacement: adım 6, 3 resimden 1. Acer Aspire 3 A315-58-350L Battery Replacement: adım 6, 3 resimden 2. Acer Aspire 3 A315-58-350L Battery Replacement: adım 6, 3 resimden 3.
    • Lift the battery up and out of the chassis.
Sonuç
Evan Sandoval
861 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 54
