Ana içeriğe geç
Acer Aspire 3 A315-58-350L Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire 3 A315-58-350L Screen Replacement, Lower Case: adım 1, 2 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement, Lower Case: adım 1, 2 resimden 2.
    • Remove the eleven 7 mm Phillips screws that secure the lower case.
  2. Acer Aspire 3 A315-58-350L Screen Replacement: adım 2, 3 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement: adım 2, 3 resimden 2. Acer Aspire 3 A315-58-350L Screen Replacement: adım 2, 3 resimden 3.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry along the perimeter until the lower case releases.
    • Lift off the lower case.
  3. Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: adım 3, 3 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: adım 3, 3 resimden 2. Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: adım 3, 3 resimden 3.
    • Use an opening tool to lift and disconnect the Wi-Fi card antenna cables.
    • Remove the single 2 mm Phillips screw that secures the Wi-Fi card.
    • Pull the Wi-Fi card directly out of its socket.
  4. Acer Aspire 3 A315-58-350L Screen Replacement, Screen: adım 4, 2 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement, Screen: adım 4, 2 resimden 2.
    • Remove the six 4 mm Phillips screws that secure the hinges.
    • There are three screws securing each bracket.
  5. Acer Aspire 3 A315-58-350L Screen Replacement: adım 5, 2 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement: adım 5, 2 resimden 2.
    • Use tweezers to grab both ends of the display connector.
    • Pull the connector directly out of its socket.
  6. Acer Aspire 3 A315-58-350L Screen Replacement: adım 6, 3 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement: adım 6, 3 resimden 2. Acer Aspire 3 A315-58-350L Screen Replacement: adım 6, 3 resimden 3.
    • Lift the laptop and gently separate the display assembly from the lower chassis.
  7. Acer Aspire 3 A315-58-350L Screen Replacement: adım 7, 3 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement: adım 7, 3 resimden 2. Acer Aspire 3 A315-58-350L Screen Replacement: adım 7, 3 resimden 3.
    • Insert an opening tool between the bezel and display
    • Pry around the entire perimeter of the screen until the bezel releases.
    • Pull the bezel away from the hinges to remove it.
  8. Acer Aspire 3 A315-58-350L Screen Replacement: adım 8, 3 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement: adım 8, 3 resimden 2. Acer Aspire 3 A315-58-350L Screen Replacement: adım 8, 3 resimden 3.
    • Remove the six 3 mm Phillips screws that secure the two hinges.
    • There are three screws that secure each hinge.
  9. Acer Aspire 3 A315-58-350L Screen Replacement: adım 9, 3 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement: adım 9, 3 resimden 2. Acer Aspire 3 A315-58-350L Screen Replacement: adım 9, 3 resimden 3.
    • Remove the two 3 mm Phillips screws on the bottom left and right corner of the screen.
    • Use an opening tool to separate the display from the display assembly.
  10. Acer Aspire 3 A315-58-350L Screen Replacement: adım 10, 3 resimden 1. Acer Aspire 3 A315-58-350L Screen Replacement: adım 10, 3 resimden 2. Acer Aspire 3 A315-58-350L Screen Replacement: adım 10, 3 resimden 3.
    • Use the tweezers to lift brass display connector hinge.
    • Pull the display connector directly out of its socket.
    • Remove the display.
Sonuç
Evan Sandoval
861 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 25
Her zaman: 56
