Ana içeriğe geç
Acer Aspire 3000 Battery Replacement
  1. Acer Aspire 3000 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Battery Replacement: adım 2, 2 resimden 1. Acer Aspire 3000 Battery Replacement: adım 2, 2 resimden 2.
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Battery Replacement: adım 3, 2 resimden 1. Acer Aspire 3000 Battery Replacement: adım 3, 2 resimden 2.
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
roro6730
351 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,026
