Ana içeriğe geç
Acer Aspire 3000 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire 3000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Keyboard Replacement: adım 2, 2 resimden 1. Acer Aspire 3000 Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Keyboard Replacement: adım 3, 2 resimden 1. Acer Aspire 3000 Keyboard Replacement: adım 3, 2 resimden 2.
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Lift the laptop to be on its edge, with the bottom of the screen in the air.
  5. Acer Aspire 3000 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
  6. Acer Aspire 3000 Keyboard Replacement: adım 6, 2 resimden 1. Acer Aspire 3000 Keyboard Replacement: adım 6, 2 resimden 2.
    • Wedge a spudger into the latch on the right side.
    • Open the lid completely to facilitate removal.
    • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
    • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
  7. Acer Aspire 3000 Keyboard Replacement: adım 7, 1 resimden 1.
    • Unscrew the two 4.6 mm Phillips #1 screws.
  8. Acer Aspire 3000 Keyboard Replacement: adım 8, 1 resimden 1.
    • Gently lift the top edge of the keyboard out of its place.
    • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
  9. Acer Aspire 3000 Keyboard Replacement: adım 9, 1 resimden 1.
    • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
    • Remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lykia Harper
258 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 855
