Ana içeriğe geç
Acer Aspire 3000 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire 3000 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
    FixBot'a Sor
    Yorum Ekle
  2. Acer Aspire 3000 RAM Replacement: adım 2, 2 resimden 1. Acer Aspire 3000 RAM Replacement: adım 2, 2 resimden 2.
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
    FixBot'a Sor
    Yorum Ekle
  3. Acer Aspire 3000 RAM Replacement: adım 3, 2 resimden 1. Acer Aspire 3000 RAM Replacement: adım 3, 2 resimden 2.
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
    FixBot'a Sor
    Yorum Ekle
  4. Acer Aspire 3000 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
    FixBot'a Sor
    Yorum Ekle
  5. Acer Aspire 3000 RAM Replacement: adım 5, 1 resimden 1.
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
    FixBot'a Sor
    Yorum Ekle
  6. Acer Aspire 3000 RAM Replacement: adım 6, 1 resimden 1.
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
    FixBot'a Sor
    Yorum Ekle
  7. Acer Aspire 3000 RAM Replacement: adım 7, 1 resimden 1.
    • Lift and pull the cover back towards you to detach it from the device.
    FixBot'a Sor
    Yorum Ekle
  8. Acer Aspire 3000 RAM Replacement: adım 8, 1 resimden 1.
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
    FixBot'a Sor
    Yorum Ekle
  9. Acer Aspire 3000 RAM Replacement: adım 9, 1 resimden 1.
    • Pull and lift the chip to release it from the RAM port.
    FixBot'a Sor
    Yorum Ekle
  10. Acer Aspire 3000 RAM Replacement: adım 10, 1 resimden 1.
    • Repeat step 9 to release the bottom chip from its RAM port.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
roro6730
351 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 1,124
