Ana içeriğe geç
Acer Aspire 3000 Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire 3000 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
    FixBot'a Sor
    Yorum Ekle
  2. Acer Aspire 3000 Screen Replacement: adım 2, 2 resimden 1. Acer Aspire 3000 Screen Replacement: adım 2, 2 resimden 2.
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
    FixBot'a Sor
    Yorum Ekle
  3. Acer Aspire 3000 Screen Replacement: adım 3, 2 resimden 1. Acer Aspire 3000 Screen Replacement: adım 3, 2 resimden 2.
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
    FixBot'a Sor
    Yorum Ekle
  4. Acer Aspire 3000 Screen Replacement, Wireless Card: adım 4, 1 resimden 1.
    • Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
    FixBot'a Sor
    Yorum Ekle
  5. Acer Aspire 3000 Screen Replacement: adım 5, 1 resimden 1.
    • Pop the three side tabs out of the back case.
    FixBot'a Sor
    Yorum Ekle
  6. Acer Aspire 3000 Screen Replacement: adım 6, 1 resimden 1.
    • Remove the panel that covers the graphics card.
    FixBot'a Sor
    Yorum Ekle
  7. Acer Aspire 3000 Screen Replacement: adım 7, 1 resimden 1.
    • Remove the black and white cables attached to the graphics card.
    • Be careful to lift vertically as to not mess up either part of the connectors.
    FixBot'a Sor
    Yorum Ekle
  8. Acer Aspire 3000 Screen Replacement: adım 8, 1 resimden 1.
    • Push the white flanges on either side of the graphics card out.
    • The card should lift on its own slightly out of the case.
    FixBot'a Sor
    Yorum Ekle
  9. Acer Aspire 3000 Screen Replacement: adım 9, 1 resimden 1.
    • Remove the card by lifting up and away from the edge that has all of the contacts on it.
    FixBot'a Sor
    Yorum Ekle
  10. Acer Aspire 3000 Screen Replacement, Keyboard: adım 10, 1 resimden 1.
    • Lift the laptop to be on its edge, with the bottom of the screen in the air.
    FixBot'a Sor
    Yorum Ekle
  11. Acer Aspire 3000 Screen Replacement: adım 11, 1 resimden 1.
    • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
    FixBot'a Sor
    Yorum Ekle
  12. Acer Aspire 3000 Screen Replacement: adım 12, 2 resimden 1. Acer Aspire 3000 Screen Replacement: adım 12, 2 resimden 2.
    • Wedge a spudger into the latch on the right side.
    • Open the lid completely to facilitate removal.
    • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
    • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
    FixBot'a Sor
    Yorum Ekle
  13. Acer Aspire 3000 Screen Replacement: adım 13, 1 resimden 1.
    • Unscrew the two 4.6 mm Phillips #1 screws.
    FixBot'a Sor
    Yorum Ekle
  14. Acer Aspire 3000 Screen Replacement: adım 14, 1 resimden 1.
    • Gently lift the top edge of the keyboard out of its place.
    • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
    FixBot'a Sor
    Yorum Ekle
  15. Acer Aspire 3000 Screen Replacement: adım 15, 1 resimden 1.
    • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
  16. Acer Aspire 3000 Screen Replacement, Screen: adım 16, 1 resimden 1.
    • Lift the connector attached to a black cable that leads to the screen of the laptop.
    • Be sure to lift vertically, moving your hand slightly towards and away from you as necessary to gently separate the connectors.
    FixBot'a Sor
    Yorum Ekle
  17. Acer Aspire 3000 Screen Replacement: adım 17, 2 resimden 1. Acer Aspire 3000 Screen Replacement: adım 17, 2 resimden 2.
    • Using a spudger, free the grey cable from underneath the plastic bars holding it within the body of the laptop.
    FixBot'a Sor
    Yorum Ekle
  18. Acer Aspire 3000 Screen Replacement: adım 18, 3 resimden 1. Acer Aspire 3000 Screen Replacement: adım 18, 3 resimden 2. Acer Aspire 3000 Screen Replacement: adım 18, 3 resimden 3.
    • Rotate the laptop to where it is standing on its side.
    • Take the black and white ended cable that was disconnnected earlier and straighten it out on the underside of the laptop.
    • Pull the cable through to the keyboard side of the laptop.
    FixBot'a Sor
    Yorum Ekle
  19. Acer Aspire 3000 Screen Replacement: adım 19, 3 resimden 1. Acer Aspire 3000 Screen Replacement: adım 19, 3 resimden 2. Acer Aspire 3000 Screen Replacement: adım 19, 3 resimden 3.
    • Unscrew the four 4.6 mm screws located here.
    • Unscrewing one screw from each side at a time and then supporting the screen as the final screws are removed will help protect the laptop's components.
    FixBot'a Sor
    Yorum Ekle
  20. Acer Aspire 3000 Screen Replacement: adım 20, 2 resimden 1. Acer Aspire 3000 Screen Replacement: adım 20, 2 resimden 2.
    • Lift the screen and its casing away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  21. Acer Aspire 3000 Screen Replacement: adım 21, 3 resimden 1. Acer Aspire 3000 Screen Replacement: adım 21, 3 resimden 2. Acer Aspire 3000 Screen Replacement: adım 21, 3 resimden 3.
    • Using a spudger, push the four rubber circles covering the screws for the upper casing.
    • Unscrew the four 4.6 mm screws that were just uncovered.
    • There may be some residual adhesive on the top of the screws, this will not harm the driver as you remove the screws.
    FixBot'a Sor
    Yorum Ekle
  22. Acer Aspire 3000 Screen Replacement: adım 22, 3 resimden 1. Acer Aspire 3000 Screen Replacement: adım 22, 3 resimden 2. Acer Aspire 3000 Screen Replacement: adım 22, 3 resimden 3.
    • Begin prying apart the two halves of the screen casing, starting at the bottom near where the cables enter the casing.
    • The process for separating the two halves is to take a spudger, inserting and twisting it until the tabs holding the casing together audibly pop.
    • Slide the spudger down the divide between the casings, twisting it whenever a tab is encountered to release it.
    FixBot'a Sor
    Yorum Ekle
  23. Acer Aspire 3000 Screen Replacement: adım 23, 3 resimden 1. Acer Aspire 3000 Screen Replacement: adım 23, 3 resimden 2. Acer Aspire 3000 Screen Replacement: adım 23, 3 resimden 3.
    • After the bottom has been freed and the side of the casing has started to separate, one's hands can be used safely to pry apart the rest of the casing.
    FixBot'a Sor
    Yorum Ekle
  24. Acer Aspire 3000 Screen Replacement: adım 24, 3 resimden 1. Acer Aspire 3000 Screen Replacement: adım 24, 3 resimden 2. Acer Aspire 3000 Screen Replacement: adım 24, 3 resimden 3.
    • Release the two connectors from the screen to the circuit board on the bottom of the casing.
    • Unscrew the grounding screw for the black cable.
    FixBot'a Sor
    Yorum Ekle
  25. Acer Aspire 3000 Screen Replacement: adım 25, 1 resimden 1.
    • Undo the four 4.6mm screws located above and below the screen.
    FixBot'a Sor
    Yorum Ekle
  26. Acer Aspire 3000 Screen Replacement: adım 26, 2 resimden 1. Acer Aspire 3000 Screen Replacement: adım 26, 2 resimden 2.
    • Remove the two lateral 4.6 mm screws on each side of the screen.
    • 'To avoid stripping out the screws, this step may require you to lift the screen away from the case to access the screws.
    FixBot'a Sor
    Yorum Ekle
  27. Acer Aspire 3000 Screen Replacement: adım 27, 1 resimden 1.
    • Tilt the top of the screen out of the case towards you, and then separate the screen from the metal frame that secures it to the casing and remove the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Perona
137 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 1,684
