Ana içeriğe geç
Acer Aspire 3410 Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire 3410 Screen Replacement, Unscrewing bottom lid: adım 1, 2 resimden 1. Acer Aspire 3410 Screen Replacement, Unscrewing bottom lid: adım 1, 2 resimden 2.
    • Remove the battery
    • Turn the laptop so that the lid touches the table and unscrew the screws. There are 14 long ones and 2 short ones.
  2. Acer Aspire 3410 Screen Replacement, Unscrew Upper Lid: adım 2, 3 resimden 1. Acer Aspire 3410 Screen Replacement, Unscrew Upper Lid: adım 2, 3 resimden 2. Acer Aspire 3410 Screen Replacement, Unscrew Upper Lid: adım 2, 3 resimden 3.
    • Pop up the keyboard with a flat screw driver. Pay attention to the connector between the keyboard and the mother board.
    • Disconnect the keyboard from the motherboard by lifting the black part of the FPC connector.
    • Unscrew 8 screws.
  3. Acer Aspire 3410 Screen Replacement, Disconnect Upper Lid: adım 3, 3 resimden 1. Acer Aspire 3410 Screen Replacement, Disconnect Upper Lid: adım 3, 3 resimden 2. Acer Aspire 3410 Screen Replacement, Disconnect Upper Lid: adım 3, 3 resimden 3.
    • Disconnect the two flat cables with the FPC connectors as shown in the picture.
    • Detach the lid and disconnect the sound card reader (red/black cable pair).
  4. Acer Aspire 3410 Screen Replacement, Unscrew Screen Lid: adım 4, 3 resimden 1. Acer Aspire 3410 Screen Replacement, Unscrew Screen Lid: adım 4, 3 resimden 2. Acer Aspire 3410 Screen Replacement, Unscrew Screen Lid: adım 4, 3 resimden 3.
    • Unscrew the four screw in the screen lid.
    • Slide out the 4 lockers on the side of the screen. Be careful not to have the screen touch the motherboard as it might scratch the surface of the screen.
  5. Acer Aspire 3410 Screen Replacement: adım 5, 1 resimden 1.
    • Disconnect the screen from the motherboard.
    • Connect the new screen and make sure to tape the cable to the screen (the connector should have a tape, if not, add one).
Sonuç
Bir başkası bu kılavuzu tamamladı.
contact@kbl.netlib.re
416 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 837
