Ana içeriğe geç
Acer Aspire 4520-5464 CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 4520-5464 CD/DVD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 CD/DVD Drive Replacement: adım 2, 2 resimden 1. Acer Aspire 4520-5464 CD/DVD Drive Replacement: adım 2, 2 resimden 2.
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 CD/DVD Drive Replacement: adım 3, 1 resimden 1.
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: adım 4, 3 resimden 1. Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: adım 4, 3 resimden 2. Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: adım 4, 3 resimden 3.
    • Remove 7 of the 2mm Phillips #1 screw from the largest panel on back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 CD/DVD Drive Replacement: adım 5, 1 resimden 1.
    • Remove the .5mm Phillips #1 black screw located on the left side of the panel opening.
  6. Acer Aspire 4520-5464 CD/DVD Drive Replacement: adım 6, 2 resimden 1. Acer Aspire 4520-5464 CD/DVD Drive Replacement: adım 6, 2 resimden 2.
    • Using the screwdriver, push the CD drive out of the laptop through the panel exposure.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ethan Woltersdorf
270 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 441
