Ana içeriğe geç
Acer Aspire 4520-5464 Graphics Card Replacement
Neye ihtiyacın var
  1. Acer Aspire 4520-5464 Graphics Card Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Graphics Card Replacement: adım 2, 2 resimden 1. Acer Aspire 4520-5464 Graphics Card Replacement: adım 2, 2 resimden 2.
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Graphics Card Replacement: adım 3, 1 resimden 1.
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: adım 4, 3 resimden 1. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: adım 4, 3 resimden 2. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: adım 4, 3 resimden 3.
    • Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
    • Set the screws aside.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Graphics Card Replacement: adım 5, 1 resimden 1.
    • Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
  6. Acer Aspire 4520-5464 Graphics Card Replacement: adım 6, 1 resimden 1.
    • Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
  7. Acer Aspire 4520-5464 Graphics Card Replacement: adım 7, 2 resimden 1. Acer Aspire 4520-5464 Graphics Card Replacement: adım 7, 2 resimden 2.
    • Lift up the heat sink line and remove the graphics card.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hunter Gilcrease
367 İtibar
3 adet Kılavuz yazıldı
Ekip
Bir Yorum
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
Fernando Rodrigues - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 2,434
