Ana içeriğe geç
Acer Aspire 4520-5464 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire 4520-5464 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 RAM Replacement: adım 2, 2 resimden 1. Acer Aspire 4520-5464 RAM Replacement: adım 2, 2 resimden 2.
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 RAM Replacement: adım 3, 1 resimden 1.
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 RAM Replacement, RAM: adım 4, 2 resimden 1. Acer Aspire 4520-5464 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Remove the seven 2mm Phillips #1 screws from the largest panel on back of the laptop.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 RAM Replacement: adım 5, 3 resimden 1. Acer Aspire 4520-5464 RAM Replacement: adım 5, 3 resimden 2. Acer Aspire 4520-5464 RAM Replacement: adım 5, 3 resimden 3.
    • Push the white tabs located on either side of the top stick of RAM outward.
    • Remove the RAM from the slot on the motherboard.
    • Repeat for the bottom stick of RAM.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ethan Woltersdorf
270 İtibar
2 adet Kılavuz yazıldı
Ekip
Bir Yorum
interesting good job
Maren Eras - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,265
