Ana içeriğe geç
Acer Aspire 4520-5464 WiFi Wireless Card Replacement
Neye ihtiyacın var
  1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: adım 2, 2 resimden 1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: adım 2, 2 resimden 2.
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: adım 3, 1 resimden 1.
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: adım 4, 2 resimden 1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: adım 4, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the two 0.5mm screws from the smallest panel on the back of the computer.
    • Set the screws aside.
    • Lift up the panel using the indent located on the left side of the panel.
  5. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: adım 5, 1 resimden 1.
    • Remove both the black and white wires by pinching the brass connectors and pulling up.
  6. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: adım 6, 1 resimden 1.
    • Remove the two 0.5mm Phillips #1 black screws located on the WiFi card.
  7. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: adım 7, 1 resimden 1.
    • Lift the WiFi card on the left side to remove it.
Sonuç
To reassemble your device, follow these instructions in reverse order with a new WiFi wireless card.
Byeloth Hermanson
285 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 1,050
