Ana içeriğe geç
Acer Aspire 4741G-332G32Mn Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the lock latch to unlock battery.
  2. Acer Aspire 4741G-332G32Mn Motherboard Replacement: adım 2, 1 resimden 1.
    • Slide the middle latch and remove the battery.
  3. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: adım 3, 3 resimden 1. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: adım 3, 3 resimden 2. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: adım 3, 3 resimden 3.
    • Pry off the keyboard using the opening tool.
    • Remove the two screws that are connected to the motherboard using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove all 12 screws from the backplate using a Phillips #0 screwdriver.
  5. Acer Aspire 4741G-332G32Mn Motherboard Replacement: adım 5, 1 resimden 1.
    • Using the prying tool to remove the bottom of the laptop.
  6. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: adım 6, 2 resimden 1. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: adım 6, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the eight screws that hold the motherboard to the frame of the laptop.
    • Disconnect the USB port from the motherboard.
  7. Acer Aspire 4741G-332G32Mn Motherboard Replacement: adım 7, 2 resimden 1. Acer Aspire 4741G-332G32Mn Motherboard Replacement: adım 7, 2 resimden 2.
    • Unscrew the 6 screws that hold the fan to the motherboard using the same screwdriver.
  8. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Remove the motherboard from the device.
Sonuç
Christopher Carstairs
256 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G6, Simcock Spring 2019 UMass Dartmouth, Team S2-G6, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G6
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,132
