Ana içeriğe geç
Acer Aspire 4741G-332G32Mn Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire 4741G-332G32Mn Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Push the blue opening tool between the edge of the computer and the screen. Slide the tool around the perimeter of the screen.
  2. Acer Aspire 4741G-332G32Mn Screen Replacement: adım 2, 1 resimden 1.
    • Pop the two circle screw caps off and remove the two screws using a Phillips #0 screwdriver.
    • Remove the computer's frame.
  3. Acer Aspire 4741G-332G32Mn Screen Replacement: adım 3, 2 resimden 1. Acer Aspire 4741G-332G32Mn Screen Replacement: adım 3, 2 resimden 2.
    • Remove the six screws from the four corners of the screen using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Screen Replacement: adım 4, 1 resimden 1.
    • Remove the screws from along the sides of the screen (two on each side) using the Phillips #0 screwdriver.
    • Remove the screen adapter from the screen.
    • Remove the screen from the rest of the laptop.
Sonuç
kristen
364 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G6, Simcock Spring 2019 UMass Dartmouth, Team S2-G6, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G6
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 715
