Ana içeriğe geç
Acer Aspire 4743-6481 DVD Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 4743-6481 DVD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 DVD Drive Replacement: adım 2, 1 resimden 1.
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 DVD Drive Replacement: adım 3, 1 resimden 1.
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 DVD Drive Replacement, DVD Drive: adım 4, 1 resimden 1.
    • Remove the 7.0 mm screw, circled in the picture, using a Phillips head screwdriver.
  5. Acer Aspire 4743-6481 DVD Drive Replacement: adım 5, 1 resimden 1.
    • Once the screw is removed, the DVD drive should easily slide out
  6. Acer Aspire 4743-6481 DVD Drive Replacement: adım 6, 1 resimden 1.
    • Remove the drive completely.
  7. Acer Aspire 4743-6481 DVD Drive Replacement: adım 7, 2 resimden 1. Acer Aspire 4743-6481 DVD Drive Replacement: adım 7, 2 resimden 2.
    • Face the side of the DVD drive that connects to the laptop and remove the 3mm screw with a Phillips head screwdriver.
    • Put the screw and the bracket to the side as you may need it for your replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Filippo Santoro
240 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G1, Lacy Spring 2017 USF Tampa, Team S5-G1, Lacy Spring 2017 üyesi
USFT-LACY-S17S5G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 661
