Ana içeriğe geç
Acer Aspire 4743-6481 Ram Card Replacement
Neye ihtiyacın var
  1. Acer Aspire 4743-6481 Ram Card Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Ram Card Replacement: adım 2, 1 resimden 1.
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Ram Card Replacement: adım 3, 1 resimden 1.
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Ram Card Replacement, RAM Card: adım 4, 1 resimden 1.
    • Remove three 7.0 mm screws with a Phillips head screwdriver from the back panel to gain access to the RAM cards.
  5. Acer Aspire 4743-6481 Ram Card Replacement: adım 5, 1 resimden 1.
    • Place the device with the battery side facing up, as shown on the picture.
    • After removing the back panel, you will see the RAM cards located to the right.
  6. Acer Aspire 4743-6481 Ram Card Replacement: adım 6, 1 resimden 1.
    • You should notice a silver tab on each side of the RAM card. Push each tab away at the same time to detach the card.
  7. Acer Aspire 4743-6481 Ram Card Replacement: adım 7, 1 resimden 1.
    • If done successfully, the RAM should pop out and you can lift it out with no effort.
Sonuç
AL-Moatasem
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G1, Lacy Spring 2017 USF Tampa, Team S5-G1, Lacy Spring 2017 üyesi
USFT-LACY-S17S5G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 706
