Giriş
If your device's screen display is distorted, cracked, flickers, or has tiny dots, replacing the screen will probably solve these issues.
Neye ihtiyacın var
Position the laptop so you have a clear view of the front of the screen.
Remove the two screw covers at the bottom sides of the screen casing using a flat tool.
Remove the two 5.0 mm Phillips screws. They will be directly underneath the screw covers.
To reassemble your device, carefully follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
