Ana içeriğe geç
Giriş
This guide will show detailed steps to carefully disassemble the laptop, and replace the internal hard drive.
Parçalar
Hiçbir parça belirtilmedi.
  1. Lay the laptop upside down. Locate and unscrew the  seven phillips head screws.
    • Lay the laptop upside down.
    • Locate and unscrew the seven phillips head screws.
  2. Remove the cover panel from the laptop
    • Remove the cover panel from the laptop
  3. Remove the hard drive from the laptop by using a Spudger tool to pry it out. Remove the hard drive from the laptop by using a Spudger tool to pry it out. Remove the hard drive from the laptop by using a Spudger tool to pry it out.
    • Remove the hard drive from the laptop by using a Spudger tool to pry it out.
Sonuç
Bir Yorum
Yes, but how do you get the hard drive out of its carrier, for example in order to replace it with an SSD?
Philip Le Riche - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 304
