Ana içeriğe geç
Acer Aspire 4810TZ-4120 Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire 4810TZ-4120 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Unlock the battery by pushing and holding the lock button.
  2. Acer Aspire 4810TZ-4120 Screen Replacement: adım 2, 2 resimden 1. Acer Aspire 4810TZ-4120 Screen Replacement: adım 2, 2 resimden 2.
    • While holding the lock button, pull out the battery
    • The battery is now ready to be replaced with a new one
  3. Acer Aspire 4810TZ-4120 Screen Replacement, Screen: adım 3, 2 resimden 1. Acer Aspire 4810TZ-4120 Screen Replacement, Screen: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Locate and remove the four (4) pads using Angled Tweezers
  4. Acer Aspire 4810TZ-4120 Screen Replacement: adım 4, 2 resimden 1. Acer Aspire 4810TZ-4120 Screen Replacement: adım 4, 2 resimden 2.
    • Remove the four screws that were under the pads
  5. Acer Aspire 4810TZ-4120 Screen Replacement: adım 5, 3 resimden 1. Acer Aspire 4810TZ-4120 Screen Replacement: adım 5, 3 resimden 2. Acer Aspire 4810TZ-4120 Screen Replacement: adım 5, 3 resimden 3.
    • Carefully pull the bevel (frame) off of the screen
  6. Acer Aspire 4810TZ-4120 Screen Replacement: adım 6, 3 resimden 1. Acer Aspire 4810TZ-4120 Screen Replacement: adım 6, 3 resimden 2. Acer Aspire 4810TZ-4120 Screen Replacement: adım 6, 3 resimden 3.
    • Locate the four screws that are holding the screen in place
    • Remove the screws
  7. Acer Aspire 4810TZ-4120 Screen Replacement: adım 7, 2 resimden 1. Acer Aspire 4810TZ-4120 Screen Replacement: adım 7, 2 resimden 2.
    • Pull the screen out gently
    • Lay the screen down on the keyboard
  8. Acer Aspire 4810TZ-4120 Screen Replacement: adım 8, 2 resimden 1. Acer Aspire 4810TZ-4120 Screen Replacement: adım 8, 2 resimden 2.
    • Locate the connector between the screen and the computer
    • Remove any tape
  9. Acer Aspire 4810TZ-4120 Screen Replacement: adım 9, 1 resimden 1.
    • Gently pull the connector off of the screen
    • The screen can now be replaced with a new one
Sonuç
Sean Howard
208 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 480
