Giriş
This step by step guide will show you how to replace the CPU in your Acer Aspire 5100.
Neye ihtiyacın var
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Loosen the screw to the CPU by rotating counter clockwise. The use of a flat head screwdriver will be needed.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Hello sir
Can I switch to cpu amd advanced chip intel or I can not do so
Thank you
Message me on email
rabaharif1993@gmail.com
