Ana içeriğe geç
Acer Aspire 5100 CPU Replacement
Neye ihtiyacın var
  1. Acer Aspire 5100 CPU Replacement, Fan: adım 1, 1 resimden 1.
    • Flip the laptop upside-down.
    • Remove the battery as a safety precaution.
    • Remove the four screws attached to the large panel.
  2. Acer Aspire 5100 CPU Replacement: adım 2, 1 resimden 1.
    • Lift and remove the panel.
  3. Acer Aspire 5100 CPU Replacement: adım 3, 1 resimden 1.
    • Remove the two screws attached to the fan.
  4. Acer Aspire 5100 CPU Replacement: adım 4, 2 resimden 1. Acer Aspire 5100 CPU Replacement: adım 4, 2 resimden 2.
    • Lift the fan and detach the cable that connects the fan to the motherboard.
    • The fan can break easily. Be careful when removing.
    • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
  5. Acer Aspire 5100 CPU Replacement, Keyboard: adım 5, 2 resimden 1. Acer Aspire 5100 CPU Replacement, Keyboard: adım 5, 2 resimden 2.
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  6. Acer Aspire 5100 CPU Replacement: adım 6, 3 resimden 1. Acer Aspire 5100 CPU Replacement: adım 6, 3 resimden 2. Acer Aspire 5100 CPU Replacement: adım 6, 3 resimden 3.
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  7. Acer Aspire 5100 CPU Replacement: adım 7, 1 resimden 1.
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
    do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
    steve foss - Yanıt
    useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
    Valerio Vischio - Yanıt
    You do not need to remove the whole cover, in order to replace the keyboard.
    The description for this job is right.
    The switch plate cover just pops off.
    Screws revealed, secure the keyboard.
    Unclip the ribbon cable.
    Job done
    Richard -
  8. Acer Aspire 5100 CPU Replacement, Track Pad: adım 8, 1 resimden 1.
    • Remove the nine screws from the back edges of the laptop.
  9. Acer Aspire 5100 CPU Replacement: adım 9, 3 resimden 1. Acer Aspire 5100 CPU Replacement: adım 9, 3 resimden 2. Acer Aspire 5100 CPU Replacement: adım 9, 3 resimden 3.
    • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
    • Use the spudger to pry open the sides of this cover.
    • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
  10. Acer Aspire 5100 CPU Replacement: adım 10, 2 resimden 1. Acer Aspire 5100 CPU Replacement: adım 10, 2 resimden 2.
    • Slightly lift up the cover to see the ribbon connection.
    • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
    • Lift up the cover from the laptop.
  11. Acer Aspire 5100 CPU Replacement: adım 11, 1 resimden 1.
    • On the cover that was removed, flip it around and locate where the back of the track pad is.
    • Remove the three screws located at the corners.
    • Lift up the bracket that you just unscrewed and remove track pad.
  12. Acer Aspire 5100 CPU Replacement, LCD Monitor: adım 12, 1 resimden 1.
    • Remove the two screws from each corner beneath the LCD screen.
  13. Acer Aspire 5100 CPU Replacement: adım 13, 2 resimden 1. Acer Aspire 5100 CPU Replacement: adım 13, 2 resimden 2.
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  14. Acer Aspire 5100 CPU Replacement: adım 14, 2 resimden 1. Acer Aspire 5100 CPU Replacement: adım 14, 2 resimden 2.
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  15. Acer Aspire 5100 CPU Replacement: adım 15, 1 resimden 1.
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  16. Acer Aspire 5100 CPU Replacement: adım 16, 1 resimden 1.
    • Lift up the monitor to detach it.
  17. Acer Aspire 5100 CPU Replacement, Motherboard: adım 17, 1 resimden 1.
    • Remove the 15 screws from the motherboard.
    • There is normally only one remaining screw attached to the motherboard on the bottom right beneath the tape.
    • All the other screw holes (except screws holding the base cover on) are kept empty.
  18. Acer Aspire 5100 CPU Replacement: adım 18, 1 resimden 1.
    • Locate the heat sink, which is the copper "L" shaped component, and unscrew the four screws that connect it to the motherboard.
  19. Acer Aspire 5100 CPU Replacement: adım 19, 1 resimden 1.
    • Push out the back of the casing by the VGA connector to remove the motherboard.
  20. Acer Aspire 5100 CPU Replacement: adım 20, 2 resimden 1. Acer Aspire 5100 CPU Replacement: adım 20, 2 resimden 2.
    • Lift up and remove the motherboard from the laptop casing.
    • Remove the USB add-on card to use it with the new motherboard.
    • To remove, grab on the sides and lift upward.
  21. Acer Aspire 5100 CPU Replacement, CPU: adım 21, 1 resimden 1.
    • Loosen the screw to the CPU by rotating counter clockwise. The use of a flat head screwdriver will be needed.
  22. Acer Aspire 5100 CPU Replacement: adım 22, 1 resimden 1.
    • Carefully pull up on the CPU from the circuit board without twisting or rotating as connections may become bent.
    • You now have the CPU, you may inspect it to check for any damages or replacement as necessary
Sonuç
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hello sir
Can I switch to cpu amd advanced chip intel or I can not do so
Thank you
Message me on email
rabaharif1993@gmail.com
rabah arif - Yanıt
It is not worth the improvement.
Imi13 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 4,622
