Ana içeriğe geç
Acer Aspire 5100 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire 5100 RAM Replacement, RAM: adım 1, 2 resimden 1. Acer Aspire 5100 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Remove the screws on the large panel.
    • Lift up the panel.
  2. Acer Aspire 5100 RAM Replacement: adım 2, 3 resimden 1. Acer Aspire 5100 RAM Replacement: adım 2, 3 resimden 2. Acer Aspire 5100 RAM Replacement: adım 2, 3 resimden 3.
    • The RAM slots are located in the corner opposite to the cooling fan.
    • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
    • Slide in the RAM at a 45 degree angle.
    • Press down on the RAM until it snaps into place.
    • A good amount of pressure is needed to snap it in place.
    • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Brad Rollinson
1.113 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G39
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 16,278
