Ana içeriğe geç
Acer Aspire 5100 Track Pad Replacement
Neye ihtiyacın var
  1. Acer Aspire 5100 Track Pad Replacement, Keyboard: adım 1, 2 resimden 1. Acer Aspire 5100 Track Pad Replacement, Keyboard: adım 1, 2 resimden 2.
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Track Pad Replacement: adım 2, 3 resimden 1. Acer Aspire 5100 Track Pad Replacement: adım 2, 3 resimden 2. Acer Aspire 5100 Track Pad Replacement: adım 2, 3 resimden 3.
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Track Pad Replacement: adım 3, 1 resimden 1.
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 Track Pad Replacement, Track Pad: adım 4, 1 resimden 1.
    • Remove the nine screws from the back edges of the laptop.
  5. Acer Aspire 5100 Track Pad Replacement: adım 5, 3 resimden 1. Acer Aspire 5100 Track Pad Replacement: adım 5, 3 resimden 2. Acer Aspire 5100 Track Pad Replacement: adım 5, 3 resimden 3.
    • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
    • Use the spudger to pry open the sides of this cover.
    • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
  6. Acer Aspire 5100 Track Pad Replacement: adım 6, 2 resimden 1. Acer Aspire 5100 Track Pad Replacement: adım 6, 2 resimden 2.
    • Slightly lift up the cover to see the ribbon connection.
    • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
    • Lift up the cover from the laptop.
  7. Acer Aspire 5100 Track Pad Replacement: adım 7, 1 resimden 1.
    • On the cover that was removed, flip it around and locate where the back of the track pad is.
    • Remove the three screws located at the corners.
    • Lift up the bracket that you just unscrewed and remove track pad.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brad Rollinson
1.113 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G39
5 Üyeler
10 adet Kılavuz yazıldı
3Kılavuz Yorumları
You left out about 10 screws & assemblies that have to ALSO be removed to release the cover that surrounds the keyboard and track pad.
Jack Hickey - Yanıt
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should remove the parts I mentioned before attempting to complete steps 5 to 7.
Nelson Mata - Yanıt
The Fan must also be removed before removing the touchpad/upper cover.
Nelson Mata - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 9,465
